メインコンテンツにスキップ
G815 RGB Mechanical Gaming Keyboard. Part number: Black: Tactile: 920-008984 Linear: 920-009000 Clicky: 920-009087 White: Tactile: 920-011354
How to take out the motherboard without damaging it.
So I spilt a drink on my keyboard and need to remove everything for cleaning, but I'm unable to remove the face plate from the motherboard even though I've taken all the screws out.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I've found only 1 way to take it off but it requires soldering all the back side of the motherboard to get the key heads off.
As far as trying to do it, it is very tedious as inside each key it has 2 small metal pieces (contact switchs) that are easy to break.
Unfortunately it is the only way to separate the motherboard to the front face plate.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi @trissy
Here's a teardown video that may help.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi @jayeff
I've seen that video but he doesn't go into much detail and he doesn't say how to take of the the front face, nor has he actually done it. Thank you though.
さんによる
コメントを追加
回答を追加する
Trissy さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 30
今までの合計 86
