Which size has every screw inside of an ps2 9000x?
Which size has every screw inside of an ps2 9000x? including motherboard, fan, controller/memory card input, driver and everything? i want to know because i'm gonna buy it to put on mine.
Hi!
Sorry for the delay!
Here are the screw sizes:
Case (to get the front off) screws: 1.3cm
Fan screws: 0.4cm
Motherboard/backplate screws: 0.5cm
Laser deck screws: 1.4cm
Laser metal bar holder screws: 0.2cm
Laser arm screw: 0.3cm
Motherboard to case (controller ports screw): 0.8cm
Disc rotor screw (directly on disk motor): 0.2cm
Screws near disk motor: 0.3cm
Worm motor screws: 0.3cm
Be aware that they do differ in thickness… I was not able to measure that part. Sorry.
Please let me know if I missed something, or if you have more questions!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 95
5 件のコメント
Hi! What do you mean exactly? Are all the screws missing? They are most of the time PH0. But every screw in there has different lengths. I do not know all the sizes at the moment, I can check by the end of this week, I think! Can you let me know which screws are missing at the moment? Thanks
koppie007 さんによる
literally every screws inside of it. like the cooler screws, motherboard screws, battery screws, etc...
Vitor Luiz さんによる
Alright, I'll check in the weekend to see if I can measure them :).
koppie007 さんによる
@dan0 you've made it?
Vitor Luiz さんによる
Sorry, it was really busy. Hopefully I can do it like upcomming friday or saturday. Sorry!!
koppie007 さんによる
