メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Sales of the second generation model started with model year 2000 and production ended with the 2005 model year. The second generation Neon was only available as a four-door sedan.
How to use 1997 dodge neon pcm to 2000 dodge neon
How to use 1997 dodge neon pcm for 2000 neon
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
@appiahcharles make sure it is a '97 PCM since anything older has different wiring. Models from 1997 to 2000 are interchangeable. You would most likely have to reflash the older PCM. For that you will need a scan tool as well as the proper software for your 2000 Neon. If nothing else, see how and if your 2000 runs and functions with the 97 PCM. Remember there is a multitude of functions that are controlled/monitored by the PCM.
Let' s see if @nick has a better idea about how to accomplish this, since he is the one that "messes" most with automotive scan tools etc.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
The main thing is the PCM/ECU needs to be cross compatible - the pinout and part number have to match up, and the replacement PCM has to be compatible with the other modules like the immobilizer. Once you confirm the part compatibility, then you can swap it in. Once you swap it in, you'll need a bidirectional scan tool with parts pairing support. You shouldn't need to reflash it if they work, but you do need to pair it with the SKIM immobilizer. If it's the same pinout but has a different immobilizer, reprogramming it cannot be avoided. If you have the SKIM system bypassed on the new module it avoids a lot of the programming hassles, but it makes a 25 year old car easier to steal (if it even matters?). Just don't tell your insurance company.
The scan tool needs to meet two requirements: It has to be bidirectional all system and support pairing modules. The Autel ones are able to do it but they cost an arm and a leg to the point I would only recommend buying them if you have something expen$ive to maintain (see: anything Euro) or do your own repairs a lot. If you absolutely have to have that 4 year old $31k E350, you need a good scanner -- comes with the ownership of a Benz to not get burned on repair costs. You can buy this for like $475, but make sure it has module pairing support: https://www.amazon.com/Bidirectional-689... -- if it's lacking, look at something with a fixed update subscription term as it will almost always have it. Any Autel will have it, without a question (but the 3 year subscription is expensive for some -- check the cost of the cards and see if you can avoid the ADAS tax if you do not need it). It may be cheaper to pay a little more to have it pre married to your car's immobilizer.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Appiah Charles さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 19
今までの合計 136
