メインコンテンツにスキップ
パソコンの修理に関する情報が見つかります。
21153回答 すべてを表示
PC fans always running
Dear All, I have a pc, and the fans are always running and it makes my pc run slow. It always makes a little noise. What can I do to solve this, please? Thank you. Meena
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
4 件のコメント
This question was migrated from http://meta.ifixit.com/Answers.
さんによる
Meena, what do you mean " makes my pc run slow"?
さんによる
you change your hard drive??
さんによる
Changing the hard drive has nothing to do with cleaning the computer's fans.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Turn your computer off, and put on an Anti-static wrist strap to make sure you don't accidentally damage your computer.
Look for some screws near the back of your case (possibly thumb screws). Unscrew them, and take the side panel(s) off of your computer case. Use some compressed air and possibly a pair of tweezers to remove as much dust as possible from the inside of your computer case. Be careful to not touch or scrape any of the components inside with the tweezers.
Removing as much dirt and dust as possible will likely not make the computer any faster, but it should make it quieter.
Anti-Static Wrist Strapの画像
製品
$7.95
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Your fan is coming on in an attempt to cool your machine. Overheating can cause the processor to overheat and slow down. A faulty fan can contribute to overheating. After cleaning the machine as Taylor recommended, if the fan is still making noise it may need to be replaced. Running your machine without the fan can destroy it. We may have a guide for doing this but need to know the model and make of your PC.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Meena さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,759
