Green vertical lines on my screen
How to fix green vertical lines on my screen ⁹
As far as I know the Green lines are cause by an issue with the display, to fix this you'll likely need a screen replacement.
I fixit sells a replacement screen along with the tools you'll need to replace it.
Here is the link for the screen
Samsung Galaxy S22 Ultra Screen
And here is a link for a guide for replacing the screen and battery, in this case you'll only need to replace the screen.
Samsung Galaxy S22 Ultra Screen and Battery Assembly Replacement
このアンサーは役に立ちましたか?
Likely Line Defects, caused by damage to the chip on the display's cable or damage to the cable itself.
このアンサーは役に立ちましたか?
過去 24時間: 7
過去 7 日: 24
過去 30 日: 110
今までの合計 471
1件のコメント
This not a fix, it's just saying what is the cause, so if this the cause what is the fix
Karo Kila さんによる
