メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年9月19日に発売されたiPhone 6の修理情報および修理ガイド。モデル番号:A1549、A1586、およびA1589
iFixit iPhone 6 battery is 1.5 mm longer than original Apple battery
Hi,
I got an iFixit iPhone 6 battery, and it's about 1.5 mm longer than the original battery and it won't fit inside the phone without pressure or possibly some bending.
Are the dimensions for all those batteries different from the original one, or I just got unlucky with a defective one?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Have you compared the model numbers of both batteries, and are they the same? How about a link to the page where you purchased the battery? You're sure it's not for the 6S or 6 plus?
さんによる
Yes, my original battery APN is 616-0805.
And this is the one I got from iFixit:
iPhone 6 Battery.
On battery it says:
Compatible with
iPhone 6
1ICP4/39/96
さんによる
コメントを追加
1 件の回答
Hey,
Just wondering if you checked the device compatibility list on the product page.
画像
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
The back of the phone says A1549, and it was purchased directly from Apple, unlocked. I assume it is supposed to be the "GSM North America".
Wont be able to say any other ID from iOS, as the old battery is not save to be re-installed, as I didn't compare the sizes before removing the original one. Rookie mistake.
However, the battery code 616-0805 is included in the compatibilities on product page:
"Compatible Part Numbers 616-0804, 616-0805, 616-0806, 616-0807, 616-0808, 616-0809".
If the exact part number is matching and product claims to replace it, then it is expected that size is supposed to match, right?
さんによる
@david44671 Indeed, it should certainly fit. At this point it looks like you did everything right, so I suggest contacting iFixit Store personnel to see about a replacement. There is a web form for contact, but I've always just sent them emails to support@ifixit.com. They may have further insights as to why it doesn't fit, but if not it shouldn't be an issue to get it swapped out for one that will.
さんによる
Got it. I might just got unlucky with the part. Will check with the support. Thanks.
さんによる
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 242
