combo drive won't eject disk
replaced drive and have the same problem
この質問は役に立ちましたか?
I would suspect a bad optical drive ribbon cable. The cable on this iBook G4 model is fragile. Remove the optical drive and check the ribbon cable silver contacts (the side that connects inside the logic board socket). Check if the contacts are all well aligned and not damaged. If so, replace the ribbon cable.
このアンサーは役に立ちましたか?
+ Ralph
Have you tried shutting off the machine, then booting while holding the trackpad button down? That should tell the machine to force the disc out.
このアンサーは役に立ちましたか?
I've tried rebooting with the trackpack held and have reset the PMU.
このアンサーは役に立ちましたか?
Is this the exact same problem you had before you replaced the drive? Where did the new drive come from?
same problem as I had before replacing with iFixit drive.
このアンサーは役に立ちましたか?
Do you mind telling us what that problem was? It seems it might not have been the drive.
Is the disk catching at the case? Maybe its a simple misalignment.
The disc won't eject from the drive
このアンサーは役に立ちましたか?
has nothing to do with the hard drive. I don't think I can help you.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,944
1件のコメント
Can you give us a history so that we've got something to work with?
mayer さんによる
