メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A2159、2019年7月に発売されたエントリーレベル13インチMacBook Proの改良版モデルです。カラーオプションはシルバー、スペースグレイ。
Is my connector lock missing?! How to workaround
Hello!
First time here.
I started to replace the battery on my daughter's 13" MBP A2159 laptop. I got to about the 2nd step - removing the battery daughter board flex cable - and discovered that I either have a different connector (unlikely) or the lock on this one might have broken off when replacing the screen several years ago?
Any advice gratefully received on what to do - how should I get the cable out now? And anything I should do when I connect it again?
Many thanks for the help!
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
@red24631 yes, it sure looks like it is missing. See step 11 on this guide MacBook Pro 13インチ Two Thunderbolt Ports 2019 バッテリーの交換
You could try and get a replacement connector and see if you can remove that lock from the new one and lever it into the existing connector. If not, then you would need to replace the connector by de-soldering the old one and re-soldering a new one. If you do not have the tools or the experience to solder that, you will need to have someone else do the soldering for you ;-)
The connector is a FF18-10A-R11AD-B-3H and the Apple part number is 518S00014. they are available at places like this (example only, not an endorsement for the seller)
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Thanks for the info!
For now, I just pushed it in and it seems fairly tight, so we'll see if it stays. Will have to dig deeper if not.
さんによる
@red24631 awesome! Hope it stays put and will continue to work for you. Repair is War on Entropy
さんによる
コメントを追加
回答を追加する
Red さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 31
今までの合計 227
