メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Released in May 22nd 2020. It's has a 3,500 mAh capacity and bears the EB-BA415ABY identification number which falls in line with the A41's own SM-A415 model number.
Samsung Galaxy A41 won't power on
I dropped my Galaxy A41 and the screen cracked slightly. I continued to use it but one day I let the battery drop below 5%. I plugged it in to charge, and haven't been able to turn it on since then.
I've replaced the screen, battery, and USB board at the bottom, but no luck so far. I noticed that the battery drains slowly (I charge it externally). Has anyone seen this problem? Any suggestions for troubleshooting and repair? I'm willing to do component-level repair if needed.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Hi @greg56100
Here's the troubleshooting section from the service manual for the phone.
Go to p.4 and follow the Power On troubleshooting flowchart and see how far you get.
There are board layout diagrams on p.2 → p.3 showing the location of the components that may help.
Unfortunately the browser search function (Ctrl + f) doesn't seem to work for the document so you will have to find the location of the components mentioned in the flowchart by visually searching for them. You also have to zoom in a lot - 500%+ but then it gets fuzzy.
Good luck.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
Thank you, this is very helpful. I couldn't find that document for the A41. Where do I find signals like PWRHOLD?
さんによる
@greg56100
Not sure but maybe work backwards and check the voltages on the components to check if PWRHOLD is not 1.8V e.g. L5008, L5010 etc.
If they're all OK you could assume that PWRHOLD is OK
さんによる
I found that Samsung's PMICs have a PWRHOLD signal but this phone has an MT6358 PMIC. I'll check those voltages.
さんによる
I had the same problem. But for me the flat cable from the buttons to the pads was broken so easy repair.
さんによる
コメントを追加
Hi well I will suggest you to check the following video it might help you in fixing the issue which you are facing right now with your phone: https://www.youtube.com/watch?v=z3uDA7xs...
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, that's one of the first things I tried. Didn't work.
さんによる
コメントを追加
回答を追加する
Greg さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 10
過去 30 日: 42
今までの合計 253
