HDD to SDD Conversion Possible?
I have an Early 2008 MacBook Pro (pre-unibody) and I was wondering if it is possible to do a SSD conversion.
What drive would I have to buy?
Any other accessories to make it work?
Thanks!
この質問は役に立ちましたか?
Thanks!
この質問は役に立ちましたか?
You should have no problems going to an SSD drive. I would get one that has jumpers to slow it down just in case. To get you to the correct guide for replacing it please give us the last three figures of your serial number. You can also replace the optical drive with an adapter and add the drive there.
このアンサーは役に立ちましたか?
The last three figures are 1XR.
Have you been able to locate a correct guide for me to use?
Apple MacBook Pro "Core 2 Duo" 2.4 15" (08) Specs
Identifiers: Early 2008 - MB133LL/A - MacBookPro4,1 - A1260 - 2198
Here's how to replace the hard drive:MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Hard Drive Replacement
Her's how to add a drive to the optical bay: Installing MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Dual Hard Drive
Thank you for those links! They were very helpful! :-)
I agree with Dan about not upgrading the MacBook because of its age, however , if you still want to upgrade you can buy any one of these hard drives to use:
120 GB
http://eshop.macsales.com/item/OWC/SSDEX...
240 GB
480 GB
You can also add a hard drive to your optical bay as a boot and application drive and keep you old hard drive installed for media which would give you a huge speed boost and allow you to store more than just an SSD would allow:
Data Doubler
http://www.ebay.com/itm/Apple-Macbook-Pr...
Hope this helps.
このアンサーは役に立ちましたか?
While I love SSD technology, I wouldn't upgrade such an old MacBook Pro due to the limits of the older Mac OS-X you'll need to use on it.
I thought you had a PPC version Vs Intel - Sorry ;-{
As long as you have Snow Leopard or better you should be fine.
このアンサーは役に立ちましたか?
What do you mean by older Mac OS-X? I am currently using Lion (10.7.4) on my machine.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 5,456
