iPhone 4S Camera in iPhone 4?
Hello,
today i got this weird idea, it is possible to pick the 4S camera and put it in an iPhone 4?
I know that the cables aren't compatible so you also need an A5 chip, don't you?
この質問は役に立ちましたか?
Hello,
この質問は役に立ちましたか?
this might help
このアンサーは役に立ちましたか?
thanks that really helped, so its a kinda possible but i dont think we cannot aspect any camera driver update.
I really want that! :)
but theoretically you can plant an A5 in there and then it should work?
@ Marc...No, not even in theory.
Marc, the connector on the logic board is different. It is not your IC that needs to be replaced but your connector, as well as the logic board itself, that will make the difference. The answer is no, you can not. Read the answer to this question iPhone 4s camera in iPhone 4? and the explanation right here Will the iPhone 4S camera module work in an iPhone 4? and many more. Just do a search on here and you will get confirmation on that. Hope this helps, good luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,327
2 件のコメント
oh man :/
but anyway thanks for you responses.
I think i'm going to save my money for the next generation iPhone :)
Marc さんによる
Marc, sounds like a great idea:-)
oldturkey03 さんによる
