メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendoのハンドヘルドデバイスは2011年2月に発売されました。モデル番号はCTR-001です。
Charging light turns on, but power button does nothing
When I insert the charger, the orange light comes on.
Pressing the power button does nothing. The charging light will stay on.
I tried different charges (they work on other consoles), different batteries (they work on other consoles), cleaning the power button pad with isopropyl alcohol, checked the F1 and F2 fuses, charging port, battery port, all are okay
Of course I also tried restarting with the battery out, with and without the sd card.
The sd card by the way, is empty. Not a single folder inside.
What could be the issue and more importantly, how do I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi Elise!
Usually this is caused by a broken fuse or something, but looks like that’s not is.
Can you check some caps on the motherboard and run some tests?
It is motherboard related anyway. Replacing the motherboard will most likely fix it.
Is the 3DS modded btw?
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
What caps?
I know it's motherboard related. I used the shell for a different motherboard, it has no issues.
But I want to figure out what it is and how I fix it
さんによる
Please check the resistors on the motherboard. Could also be the CPU. Did you also checked the traces? If possible, can you share some pictures with us? Thanks!
さんによる
コメントを追加
回答を追加する
Elise さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 14
今までの合計 77
