phone won't reboot after it got wet
The top 1" of the phone got coffee on it and initially it seemed to recover but now it reboots only partially and doesn't go the full cycle so will not turn on. What part do I need to repair?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Electronics Water Damage after you have cleaned your phone and inspected it I think you'll be able to see if anything is damaged or needing to be replaced. Could be speaker, earpiece, camera, simslot, motherboard. http://www.formymobile.co.uk/i9020disass...
このアンサーは役に立ちましたか?
I'd take her apart as best you can. Clean her out replace anything that has been effected by the coffee bath and put back together. If its not running afterwards taking to the carrier to see if they will repair or warranty replace the phone.
Good luck
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 2,216
