メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
さまざまなCanonシリーズレンズの修理ガイド、マニュアル、トラブルシューティングを掲載しています。
The top of my lens is slightly coming off, how to fix?
画像
画像
So basically, the top of my lens is slightly lifting on one side, which can be seen in the picture with my hand in it. Currently, it doesn't seem like too much of a concern, but I am worried that it will get worse.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The part of the lens that is lifting on one side is called the front ring assembly. There are 3 screws that are supposed to hold it in place. Based on your pictures, it appears that there is currently only one of those screws still holding it onto the lens. The other 2 screws must have broke off or the piece it was screwed onto must have broke. How easy of a repair this is would depend on exactly how those screws broke free. If you go to a 3rd party lens repair shop, they should be more than capable of making this repair too.
As to whether it'll get worse, it's hard to say. Since there seems to now only be 1 screw holding that front ring assembly on, it is under more stress and therefore could end up breaking, causing the whole front ring assembly to fall off the lens. Also in its current state, there is a higher chance of dust and debris getting inside of your lens.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Noelle McCandless さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 11
今までの合計 185
