Center button not working after following tutorial
Hey guys i have an ipod classic 80gb that had a bad click wheel, followed the tutorial step by step installed the new click wheel, went back to put it back together but now the center button doesnt work at all, re opened the ipod double checking with every step from your tutorial everything "looks" perfect, new click wheel works like a charm yet the center button still not working, what possibly went wrong?
この質問は役に立ちましたか?
6 件のコメント
when it's disassembled does the centre button still "click'? is the black foam piece in place? is it the right part?
pollytintop さんによる
hey thanks for the quick answer, yes, the black button on the logic board clicks, even assembled with the new wheel every button clicks as it "should".
the center button has its black foam in place it has some sort of plastic recovering the entire button so i havent touched it.
cleskovsek さんによる
What happened that made you replace the click wheel
oldturkey03 さんによる
the original click wheel lost almost all it sensibility to scroll around menus and stuff, but the center button was working perfectly. so i replaced the click wheel to get my ipod back to normal activity, but apparently something went wrong with the center button, but i dont know what happened. followed the ifixit tutorial with extreme caution and no, im not new at "fixing" stuff though, but certainly im not an "apple" engineer. so thats why im asking if this is a common problem, or what did i do wrong in the process?. maybe the center button attached to the logic board got burned and might need a new logic board? any help or direction on how to fix this would be really appreciated. thanks!
cleskovsek さんによる
cleskovsek did you manage to find a solution?
I have encountered the exact same problem after replacing my clickwheel (also an 80GB Classic).
Any response would be much appreciated, cheers.
Grr Ee さんによる
1以上のコメントを表示
