メインコンテンツにスキップ
PlayStation 3 (PS3)はソニーコンピューターエンターテイメントによって製造された3世代目の家庭用据え置き機で、PlayStation 2の次世代機となります。これらは2006年11月11日に発売されました。
781回答 すべてを表示
A/V Cables not working properly
Last night on the ps3, I was playing mw2(2 thumbs up for infinity ward). While playing I had a graphic issue using my HD conpeont cables that i bought for my ps3.
I don't know if the a/v cables went bad or the ps3 died. How can I find out?
If it is the cables, what kind should I get?
And by the way i have Monster Game Conpeont cables for my Ps3 fat
p.s. i own a 2usb 80gb
(400$$)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
4 件のコメント
unintelligible, again
さんによる
I need help with this
さんによる
thanks nat welch now i know how to ask this
さんによる
right now im using SD cables i had from a ps2 that broke
さんによる
コメントを追加
2件の回答
ベストアンサー
You can also try a different set of cables including if you have it the stock AV cables that came with your system. Also try a different TV set or Monitor and see if that works.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Thanks so much Nat for the translation and spelling. Who says the older generation can't communicate with the younger? This type of machine fails so many times due to cheap cables and heavy use that I would never go the cheap route. Go to Radio Shack and get the best they have. If the PlayStation is bad you will always be able to use them with a newer machine. I prefer the "Monster" brand. http://www.monstercable.com/
このアンサーは役に立ちましたか?
スコア 1
6 件のコメント:
As an audio technician, I respectfully disagree about Monster cables. In the sound industry, nearly everyone agrees that they are overpriced and not worth it.
さんによる
thanks i have a jvc tv from may 2004 and i have monster cables
さんによる
Josh, if you have a constructive comment, then you need to try to answer the question yourself. You offered no alternative, just criticism.
さんによる
I'm sorry- I didn't mean it as criticism. I simply meant it as a way to save the chap some money if he needed new cables. I tried to convey that, but I guess I failed. I apologize.
さんによる
Thanks. As an audiophile what cables do you recommend?
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Nick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,232
