メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The NuWave Brio 37001 is a 6-Quart Air Fryer with a digital screen at the top that controls temp, timing, and the wattage in which you want to prepare your food.
How to dissasemble a Nuwave Briio 6qt Airfryer
I have tried to search on the internet but to no avail except one video I found here on this website. which allowed me to join this forum. The video did show completely how to dissasemble it completely to get to the circuit board. Mine quit while I was using it. All power is gone. Presuming it shorted out due to bugs inside most likely.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Some electric heaters (coffee maker, toaster ovens, portable hair dryers and possibly air fryers, use a thermal fuse to disable power instead of causing an electrical hazard. If you are familiar with electrical/electronic circuits, you may be able to identify if a thermal fuse is blown. It's wired into the hot side of the electrical wiring, often mechanically crimped onto solid wire. Sometimes encased in a heat resistant cloth like shield. It's round and similar to resistors but it protects against short circuiting. Over current demand, overheating, opens thermal fuses from heat, A multimeter measuring resistance is used to measure it; short/good, open/blown. This presumes the airfryer wasn't soaked in dishwasher or washed under a sink that may damage everything when reconnected to power.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
RobM さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 205
