Did a windows update and now I have no signal to my monitors
I’m hoping someone can help as I’m really stuck right now. I updated my windows as I always do, chose update and shutdown. I went to use my PC next day and the PC turned on but I had no signal to either of my monitors.
I have checked the GPU which isnt the problem as I tried it in another PC. It’s not the CPU as I have just installed the same one that was originally in it( I bent the pins trying to put it back in when checking if it was the problem :/). I’ve changed power cables and HDMI cables but I’ve still got nothing to the monitors.
Please any advice or help would be appreciated.
Components:
CPU: AMD Ryzen 5 5600G -
6-Core 3.90GHz, 4.4GHz Turbo - 16MB L3 Cache Processor w/ Radeon
Graphics:
NVIDIA GEOFORCE 3060ti RTX
FAN: AMD Ryzen Wraith CPU
Cooler
M2SSD: 1TB (1x1TB) WD
Blue SN550 M.2 NVMe PCle
SSD - 2400MB/s Read &
1950MB/s Write (Single Drive)
MEMORY: 32GB (4x8GB)
DDR4/3200mhz Dual Channel
Memory (Corsair Vengeance
LPX w/Heat Spreader)
MOTHERBOARD: MSI B550M PRO-VDH: M-ATX w/ RGB
POWERSUPPLY: InWin A65 650W 80+ Certified Gaming Power Supply
2 件のコメント
Hi @harriett89323
Can you get into the BIOS menus on startup with a working display by pressing the Del key a few times?
jayeff さんによる
No I can’t access anything on the PC because I get no display
Harriett さんによる
