Can’t find replacement bit
What is the number 4 bit. 3row from bottom closest to the large screwdriver. I order what I thought it was and it was wrong one please help thanks
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@randylane if this is the one you are referring to
then you are looking at the 7mm Hex Security 1/4" Screwdriver Bit.
このアンサーは役に立ちましたか?
Hi @randylane,
Just to add to the answer above
It's very hard to see but the type/size of tool is shown under every piece.
Here's an image showing what I mean. I've only highlighted a few so as to not confuse the image.
(click on image)
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 184
2 件のコメント
@randylane what kit are you referring to?
oldturkey03 さんによる
Manta screw driver kit. When I look at the list I can’t find the exact one. The pics look the same for hex 4mm and hex security 4mm
randy lane さんによる
