could this be it?
when i was on my way in after i raised up the mother board a peace of black rubber fall out.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If it is long and very thin, it is the rubber cushion which has long slot that sits on edge (top edge) of logic board, precisely under the two screen flex cables. It is a protective device for the cables, though not absolutely necessary, just set it back into place when you put iPhone back together.
このアンサーは役に立ちましたか?
what if the screw is not screw in at all. its the one that hols a panel where all the connections from the LCD and front camera connects.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 216
