メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A2159、2019年7月に発売されたエントリーレベル13インチMacBook Proの改良版モデルです。カラーオプションはシルバー、スペースグレイ。
New battery shows normal but not charging
  • I replaced the battery with an I fix it replacement but the battery is NOT charging
    • Battery shows up in System Info
    • Health = Normal, 52% charge
    • Mac shuts off when unplugged
    • SMC/NVRAM resets did nothing
Update (05/24/25)
I opened it up and reseated the connections and it is still not working. Here is the coconutbattery window
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
さんによる
コメントを追加
1 件の回答
Check the BMC cable is properly connected and the ZIF connector latch is set.
You may want to install this gem of an App as it offers more useful info CoconutBattery snap a image of the Apps main window posting it here so we can see things.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
I responded but it didn't add it under your comment?
さんによる
@brandons73519 Try to edit the main question and add the CB image to there. From what I can see of the image everything seems to be OK.....
さんによる
@brandons73519 - mmm... The battery appears to be working and the battery is in need of a charge, it does look like the batteries temp is a bit high. Let try this shut the system down fully and disconnect the charger, let it set for a while to cool down . Now plug the charger back in and restart the system and quickly reopen CoconutBattery take note of the batteries temp and not if the battery is charging looking at Charging With it's currently zero are we getting a higher value now hopefully enough to charge the battery.
さんによる
コメントを追加
回答を追加する
Brandon S さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 25
今までの合計 203
