メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Air conditioner I was cold suddenly it turned on the light
Why is it cold at first and not cold anymore
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Ac is not ampire no more
さんによる
コメントを追加
3件の回答
最も参考になった回答
@phamphong could be the refrigerant as well as many other things in between. To prevent us from guessing, it will be very useful if you can tell us what the exact model number for your AC is, as well as what light turned on. Next tell us what you have already tried.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Sounds like the filter is clogged. The device troubleshooting may mention that, but it could also be under maintenance & upkeep. The AC transfers air through the filter to pump cool air out. A clogged filter means less air is pulled as easily, so the system works harder but less effectively than normal. https://www.google.com/search?q=amana+wa...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
You may have a heating/cooling Amana or an older style one. Years ago I used one, the owner explained that there was a water tray inside, and he showed how it needed water to function right. The water tray needed to be 50% full to function well in heating & cooling.
さんによる
The water Amana has a flip up door. Inside is a water tray which water can be poured into.
さんによる
There also may be a flap door at an AC side, which allows the tray to be pulled on. This means it can be filled after being pulled out then be pushed back in. For tray pull & press a partial fill can mean less mess.
さんによる
コメントを追加
If your AC suddenly stopped blowing cold and the light turned on, it could be a few things: a safety sensor tripped, the thermostat or control board reset, or the unit might be entering a protection mode because of low refrigerant, ice build-up on the coils, or a clogged filter.
Start with the basics: turn off the unit, unplug it, wait 5–10 minutes, then restart — this often resets the controls. Check the air filter and clean/replace it if it’s dirty. Also feel the outdoor unit — if it’s frozen, let it fully defrost before running again.
If it still won’t cool and the light keeps acting up, it might need a technician to check the control board, sensor, or refrigerant levels.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
pham phong さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 346
