メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2.2 GHz (Turbo Boost使用時最大3.4 GHz), 2.5 GHz (Turbo Boost使用時最大3.7 GHz)もしくは2.8 GHz (Turbo Boost使用時最大4.0 GHz) L3キャッシュで6 MBのクアッドコアIntel Core i7プロセッサ
MacBook screen flickering and after while it freezes with blue screen
Hello i recently bought used macbook from internet
Works very find but when i use macbook sometimes screen flicker
i dont know what cause this but i didnt care about it(it happens 1~2times while using 4-5h)
but suddenly it stopped with blue screen or pink brown or some other color
It was working fine until last week so seller is innocent (at least i think so)
I tried nvram reset/reinstall mac os/smc reset/auto graphic change? Disabled
Is there some way to fix it please help me
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
There are two versions of this series one with just the iGPU (Intel chip graphics engine) and the other with a AMD GPU chip. Do you know which you have? Here's a listing of this series:
If you take the bottom cover off you can see the difference in the heat sink as it will either only have one chip pad or two. Follow this guide to get it off MacBook Pro 15インチ Retina Display Mid 2015 下部ケース交換
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I think it is dgpu model
today it restart after freeze with white screen and it says macbook restart because of crash
I tried apple diagnostics but no error detected
さんによる
@suck24877 Can you take the bottom cover off and take a couple of good photo's so we can see, posting them here.
If you got a crash report that would be helpful when diagnostics doesn't pop an error. From the sounds of it it sounds like the GPU maybe failing or just overheating. Are you up to cleaning the logic board and re-pasting the thermal paste on both the CPU and GPU if present.
さんによる
コメントを追加
@suck24877 Here is a video on how to do the thermal paste on the CPU/GPU. just in case https://www.youtube.com/watch?v=7912tmng...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Suck さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 16
今までの合計 111
