メインコンテンツにスキップ
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
548回答 すべてを表示
hard drive slow and with strange behavior
I think my hard drive is failing because after a series of tests with Disk Utily and Apple Hardware Utility, I got errors. For example, Apple Hardware Utility test has detected an error 4HDD/11/4000000 SATA(0,0). My Mac is slow and with strange behaviour.
I think I will replace the drive, but some people said that perhaps the HD fan is with problem. But when I run iStat Pro it shows the HD fan running at 1200 rpm.
How could I be certain that the problem is only with the hard drive and not the fan?
I found the procedure to replace the fan in this site, but you don't sell this part. In case I need, where can I find the HDD fan?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
The part number for the 2.4 GHz hard drive fan for a mid 2007 iMac is 922-8202. Just Google that number. If it doesn't cost to much more, go with a new fan rather than a used part.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
sergio barrozo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,359
