メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
Broke LCD connector during screen replacement
While replacing the screen of an iPod touch 4, one of the pins broke off of the LCD connector (on the top of the logic board). The iPod does not respond at all to charging or pressing the power button--shouldn't I still get some response with only one pin broken? Is it possible I broke the ribbon cable for the power and volume buttons?
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
You probably have more than a single issue. First, once the pin is broke on the logic board, it's usually toast. I've only managed to remove and solder 1 back in with success and a lot of luck ... and I mean the whole connector, not just the pin. I did it with an old logic board that I snapped the pin off of when first worked on a touch 4g. <urk>
In any case, if you need to get some data off, you should still be able to disconnect the lcd cable from the logic board and plug the device in. Give it about 30 minutes ... since you can't see the screen ... at that time if you unplug the cable and plug it back in you should hear a beeping sound ... if you do, this means you can still plug it into a pc/mac and retrieve any data.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I'd think that I'd at least get a distorted image with only one pin broken off. You're quite right, though, there is no way I'll be able to resolder it on--I lost the pin anyways.
Thanks!
さんによる
コメントを追加
回答を追加する
Ahanu Banerjee さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 2,949
