メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Won't power on using the power button on the back of the unit
Hello,
I just picked up a Macintosh IIx that was being sold as recapped and working, but when I got it home to turn it on, it showed no signs of life. Nothing out of the power supply, and pressing the power button on the back of the unit did absolutely nothing. After some research, it was found that the power supply could be turned on by applying three volts to Pin 15, and doing so worked. The machine turned on without a problem, and made the startup chime. I checked both PRAM batteries, and they seemed to be fine. I also tried applying three volts from my bench power supply to the battery holders, but pressing the power button still did nothing. However, the power button does work for turning off the machine once it has already been started. I was wondering what could be going wrong, and how the issue can be fixed.
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Mostly those Macs get only the logiboard reccaped, the problem however are bad capacitors in the power supply.
Maybe you're lucky and it only the security bulb to be gone.. ;)
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I'm so sorry, I forgot I left this forum up! I actually managed to fix it by putting a bodge wire across a broken trace. The person I got it from had recapped it, and made some repairs to the logic board, but I guess one didn't hold!
さんによる
コメントを追加
回答を追加する
_nec6678 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 226
