メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
Touch bar works but no light. What's broken?
A friend has an A2338 whose touch bar works but doesn't light up. I've tried to troubleshoot software issues but the problem persists.
I would like to repair it, since repair shops are hard to come by around here. But I'm unsure were to start, I'm inexperienced all things apple. Can I replace just the touch bar? Or do I need to go with a whole upper case replacement?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Well I will suggest you to Ensuring your MacBook Pro is running the latest version of macOS can fix many Touch Bar issues. So Please check if your macbook is updated to it latest version if it is not updated to the latest version then I will suggest you to update it to its latest version.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I've already gone through several software troubleshooting steps, including updating to the latest version (or verifying that the latest version is installed) without success.
I'm confident it's a hardware issue
さんによる
コメントを追加
Sadly the panel its self has likely failed and will need to be replaced. Unlike a LCD panel which has a light source behind it OLED panels emit their own colored light per pixel. Here we have a matrix of lines that run across the panel to supply the signal and needed power for the panel to light up. A good bang or liquid spill can kill the panel. Here’s the guide MacBook Pro 13" Two Thunderbolt Ports 2020 Touchbar Removal besides getting a new panel as the cheaper option you might just want to get a new uppercase if your battery is also close to the end of its life as that’s less work and frankly quicker!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Manuel Luka さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 12
今までの合計 139
