メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年5月発売の13インチMacBook ProはクワッドコアIntel 第10世代Core i5/i7プロセッサ搭載でIntel Iris Plus グラフィックス搭載(モデル番号 A2251/EMC 3348、4つのThunderbolt 3ポート)
MacBook screen stuck on apple logo after erase all content and setting
-stuck like that for 24h already, no indication of any progress.
-not turning off when holding power button, screen just go black for 10s, goes to sleep or hibernate i guess and after 10s turns itself on, on it’s own, back to the original issue.
-none of the boot keyboard key combination are working since MacBook is not actually switching off.
-discharging the MacBook battery does not change anything, seems like system is restored back to the original issue from hibernation.
-MacBook plays sound when connecting charger.
-its warm
-didn't check drive usage/capacity before starting erasing. Could be “securely” erasing 10000 TB of data?
Any advice?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Why did you erase everything? Without access to the OS files the system won’t fully boot. At this point you need to restart the system and using the Startup Option keys jump into OS Recovery. Here we need to use Option-Command-R or Shift-Option-Command-R
Reference: Mac startup key combinations
このアンサーは役に立ちましたか?
スコア 0
6 件のコメント:
More context and resolution.
This is company MacBook returned by user, I usually don’t deal with those, but since there was no rush on giving it to the another user I wanted to try “Erase all content and settings” like you would do on iPhone to restore to factory default. Apparently that failed horribly and corrupted the filesystem. Mac was not responding to any Startup Option keys combination except the one initiating DFU mode. With that I revived AND restored Mac firmware and computer managed to recognise borked filesystem (folder with ? on power on). Next was network recovery where I needed reformat the SSD and install fresh OS - which was the actual goal of this exercise gone wrong.
さんによる
@angus50543 - So the system is alive now?
さんによる
Facing same issue how did you fix yours
さんによる
@davidagyei - This system required a DFU firmware recovery and then a full re-install of the OS. This was do to corporate asset tracking software installed.
さんによる
@Dan, can you please assist me with the steps for the DFU firmware recovery.
Thanks
さんによる
1以上のコメントを表示
コメントを追加
回答を追加する
Angus さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 27
今までの合計 552
