How do I open it to disconnect the piezo (it’s too loud)
Brabantia multi-zone 10l air fryer.
Can’t use it as it scares the dog out the house due to the loud piezo.
It works fine, just cannot figure out how to open it to get to the piezo to disable it.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
4 件のコメント:
Hi @markventer
Are there any feet on the bottom of the air fryer?
If there are it could be that there are screws under them.
Also check for any recessed screws under the labels as well.
Just where I'd check
さんによる
Thanks - yes I have checked all the obvious, have been able to remove the bottom half of the fryer (that the tray slides into) but cannot remove or see any way to remove the next half up to get to the control panel. Without possibly snapping something like tabs etc.
Really hoping for some definite disassembly instructions…..
さんによる
@markventer
I couldn't find any teardown videos online so if there's no obvious places for screws and if there are some "seams" between the top and bottom half it may be a snap fit case with lugs to keep it closed and secure.
You may need some pry tools to get into it.
Obviously they're not designed to be repaired or not easily anyway.
さんによる
No I could not find any info online either. It’s still under warranty and only a month old so could return it for refund but I really like it. Have reached out to manufacturer for local service/repair agent but no response so far.
Alternatively, purchased it on sale so was really cheap and I suppose I can afford to break something trying to open it.
さんによる
コメントを追加
