My ps3 move is not connecting to PS3
its not connecting to ps3 it's blink few times and going off. when i connect it to usb charging its working fine if i remove it itz saying charging error
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Amal prasad, I would start by replacing the battery inside the move. Check on this teardown to see if you would be comfortably with doing it. Check here for a new battery, after that re-evaluate for any residual problems. Good Luck.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 674
