メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
9月9日に発売されたApple最小のiPhone 14は、6.1インチの有機ELディスプレイ、進化したデュアル12MPカメラシステム、オートフォーカス付きフロントカメラを搭載しています。iPhone 13の後継モデルです。
Where is Bluetooth antenna and can I replace it?
I got an iPhone 14 on eBay with almost unusable Bluetooth connection. If you move iPods more than 2-3 inches away, it’s drops connection. Can’t see any other local devices. I found a replacement Bluetooth antenna online, but no replacement instructions. Oh, the camera had been serviced. Does anyone know where the Bluetooth antenna is? Could the camera replacement have broken the Bluetooth antenna’s connection? Thanks, r
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Yes, the Bluetooth antenna in the iPhone 14 is integrated into the upper antenna flex cable, which is located near the top right corner of the phone, close to the front camera and Face ID components. Since the camera was previously serviced, it’s very possible that the Bluetooth antenna was either disconnected, damaged, or not properly reinstalled during that repair.
Steps to Check and Replace the Bluetooth Antenna:
1. Check for Loose Connections
• Open the phone carefully and inspect the antenna flex cable near the front camera module.
• Make sure it’s securely connected to the logic board.
2. Inspect for Damage
• Look for any tears or bends in the antenna flex. Even a small tear can cause major Bluetooth issues.
3. Try a Software Reset
• Go to Settings > General > Reset > Reset Network Settings to see if that helps.
• Update iOS in case it’s a software issue.
4. Replace the Antenna Flex Cable
• If it’s damaged, you’ll need to replace it.
• Since Apple doesn’t provide official repair guides for this part, you’ll need to find a teardown that covers antenna locations.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is NOT integrated on the upper flex, it's on the bottom left speaker
さんによる
コメントを追加
回答を追加する
ralph さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 41
過去 30 日: 155
今までの合計 1,932
