Source for battery and guide to replacing it.
Anyone ever change a battery in a Garmin Nuvi 1450 and know a good source for buying a battery for it?
Thanks.
この質問は役に立ちましたか?
Thanks.
この質問は役に立ちましたか?
Amazon and/or Ebay has the battery you need, just be aware of the customer reviews on how the service has been and you should be just fine :)
I found the installation for your battery here:
http://www.batteryeducation.com/2012/02/...
If you have any issues or need the proper tools I suggest the ifixit Pro Tech Base Toolkit :)!
このアンサーは役に立ちましたか?
Thanks Gary...much appreciated!
Hey no worries Denny lemme know if you need any further help rah!
I do not have a good source for a battery but have taken mine apart to fix the contacts on the mini usb connector. front cover comes off with strong fingernail. then there are 4 mini torkx (sp) to remove and get inside, the battery and speaker have standard mini connectors. don't remember the label on the batty but it looks like it would be an easy un plug to change it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,977
1件のコメント
denny1960, if the answer worked for you, all you have left is to accept it :-) That way, anyone looking for the same solution will know what works. Thanks and good luck.
oldturkey03 さんによる
