メインコンテンツにスキップ
Released in Sept, 2018 by OPPO
How to repair my display glass only wether display
The glass of my phone's display is broken or something is damaged, I need to get it fixed
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@originaldi62402 I do not recommend that you try a glass-only repair for a display issue. I strongly recommend that you replace the complete assembly. While a glass-only repair is slightly cheaper, it is also more complicated and requires some more expensive tools. I recommend a complete display assembly replacement. It is a bit more costly but your success rate is almost guaranteed. It is also quicker then a Glass-only.
Since iFixit does not yet have a specific guide for that, use something like this video to replace the display assembly. Replacement displays for your phone are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Original display of realme C1 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 17
