メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年2月に発売されたSamsungのスマートフォン「S22 Ultra」の修理・分解情報。
Why won't my wifi turn on?
Every time it try to turn my wifi on to connect to my home wifi it never finds the connection?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Hi @jayjay94cod
Not sure as your question says "Why won't my wifi turn on?" and then says "..... it never finds the connection? A bit confusing as to what's happening. Does the WiFi turn on but not detect, turns on and then turns off or doesn't turn on at all?
If it does turn on but not detect, try using the phone's WiFi as close as possible to your home network router i.e. <10cm and check if it detects, connects and maintains a stable connection.
If it does it may be an antenna problem - loose connection (either end) or faulty antenna perhaps.
Here's the ifixit Samsung Galaxy S22 UltraのUSB-Cポートおよび充電ボードの交換 guide that may help.
The WiFi antenna is part of the interconnect flex cable seen being removed in Step.27 (the blue cable being held by the tweezers)
If you suspect that the antenna is faulty, search online for (insert full phone model number e.g. SM-S908???) WiFi flex cable to find suppliers that suit you best.
If it still doesn't detect when using the WiFi close to the router, then it may be a motherboard problem and further testing using the schematics (I can't find them) would be needed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JayJay94 cod さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 27
今までの合計 456
