メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Warning about non-HP replacement battery on boot
Since HP does not make an OEM replacement battery for HP Spectre x360 laptops, I purchased a non-HP battery from iFixit for a HP Spectre x360 15" 15-df0013dx. The battery is HP SU06XL. It installed fine and charges and works fine, but on each boot a BIOS like screen appears saying it's a non-HP battery. Then you either wait like 10 seconds or press enter to continue booting. Is there any way to stop this warning? It's not the end of the world but I would like to get rid of that warning if possible. Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi @vs35
Try the following and see if it resolves the problem:
a). Go to Device Manager > Battery and uninstall the Microsoft ACPI Compliant Control Method battery drivers. When completed, close all open windows and restart the laptop in the normal manner. During the following restart, Windows will reinstall the drivers. Check if the message appears the next time the laptop is started.
b). If still no good, type "Task Scheduler" (without the inverted commas) in the search bar on the desktop and then click on Task Scheduler > run as administrator
Once in Task Scheduler, go to Task Scheduler Library > Hewlett-Packard and click on HP Battery Health.
In the right-hand pane, right click on BatteryCheck and click on Disable.
Close Task Scheduler and restart the laptop in the normal manner an check if the message is gone.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
14vs35 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 94
今までの合計 2,401
