メインコンテンツにスキップ
iPhone 4のCDMA版モデルです。修理はそのままパーツに作業をしますが、フロントガラスとLCDはユニットで交換しなければなりません。16もしくは32 GB / Model A1349。
295回答 すべてを表示
How to fix a sunk in power button
So, my iPhone4 was perfectly fine until a couple weeks ago. I took it out of my pocket and I discovered that the power button had "sunk" in. It still functions; however, there is no click or resistance when I press it down. I have to push a lot harder in order for it to properly work. I have take then entire phone apart in order to attempt a fix, but I cant figure it out. The power sensor cable seemed perfectly fine (the yellow 'nub' was still intact). Any suggestions on what I can do to restore the original function and regain the clicking?
Any help would be greatly appreciated.
also, theres no water damage nor has the phone been dropped.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
Unfortunately that is a common problem on the iphone 4.
The problem is that originally there is a small black 'dot of plastic' on top of the switch (on the flex) which activates the switch when you press.
Most likely this black dot has disappeared from your switch. The best way to solve this is to replace the power and sensor flex assembly:
[リンクされた製品が存在しない、もしくは無効: IF189-004]
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Christian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 23,326
