メインコンテンツにスキップ
モデル番号 A1367/ 8, 16, 32 もしくは64 GB容量
914回答 すべてを表示
iPod touch 4th gen overheating
I replaced a screen and now it seems to get the temperature warning after 10-20 min of playing a game. Could I have done something while changing the screen that would cause this? It isn't the screen itself causing it. A restore and hard reset solved nothing. I don't see anything out of place or broken inside. How does an iPod keep "cool"? My theory is something got damage when it originally got smashed and the screen replacement has triggered the malfunction.....very stumped.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
I would say you are right, I had similar experiences with hot chips and it has to do with shock damage. An iPod touch I had the same problem and it also had a flickering LCD backlight (it would go out randomly and the come back on every 30 mins or so)
I ended up taking it apart and took a heatgun to the chip hoping it might reflow the solder a bit. Welp I ended up frying the chip in the process.
If I was you I would just be thankful that its working half decent and put up with it. If you go and try to fix it, be prepared for a total loss.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It happened to my ipod to try to keep the light below half to save energy and if you jailbroke your ipod try to keep background themes off thats all I got if that doesnt work take your ipod back and get a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Mike さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 5,760
