メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
9月20日にAppleが2019年に販売したiPhoneは5.8インチのOLED、3つのカメラがつき、バッテリー駆動時間が大幅に増加しました。iPhone XSの後継機です。
Screen won't wake up after sleeping until force restart
Hey bro i have an iphone 11 pro got its screen replaced a 2 months back and now after some time i leave it its display wents black but the phone works and after force restart it goes back to normal ,but note nothing happens while i am using it whenever i leave it and after some time i look back at my phone to use it it does this thing i thought it was the battery but it isnt i replaced it a week ago ,Note that my phone is fine while i am using it its screen only goes black when i dont use it for some minutes,Also i data analyzer says nand or CHarging flex or power button flex is the issue
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Haseeb, I've switched your question from an answer on an iPhone 12 question to a properly categorized question under the iPhone 11 Pro device type. You are much more likely to get a relevant answer this way, as your question was only tangentially related to the original question.
さんによる
コメントを追加
2件の回答
最も参考になった回答
Well the most basic fix to this solution is to update your iphone to it latest software version this ca help you in fixing the issue. Sometimes outdated software version can also cause this kind of issue.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Haseeb, your first task is to get us some information about the problem on your phone. Chances are pretty good that there are files called panic logs stored on your phone that may be able to tell us what's going on with it. Your job now is to read the Kernel Panics wiki page and use the information there to locate and copy the first page of the latest panic log you can find.
iPhone Kernel Panics - iFixit
Once you have that, come back and edit your new question to include a screenshot or cut'n'paste of that first page.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Haseeb Waris さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 35
今までの合計 183
