Too many apps open, how do I close them?
My iPhone says the disk space is full, when I click on the front lower button, a line of open apps appears, almost all my apps are open. How do I turn the apps off?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
To turn off the Apps, press the Home Button twice quickly as you did before. Then press and hold on one of the icons until the Red Minus Sign appears. Then tap the minus sign so they disappear. Tap the left one continously to get them closed most quickly. This is probably not the reason for the Disk Space Problem. That is most likely due to too many Photos on the iPhone, or too much music, or a FaceBook App memory error.
このアンサーは役に立ちましたか?
Double-click the Home botton, will be running the software, and then slip up, it turned off.www.iboxfix.com
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 6,930
