15インチディスプレイのMacBook Proモデル
6575の回答 すべて表示
ASAP! 2009 Display in 2008 MacBook?
I am looking for a laptop on ebay and found an ok one with no display (just the palmrest+logic board). I have found an awesome deal on an LCD + Display housing, but it is for a mid 2009 macbook pro. Will the 2 be compatible? I know they updated the display on the 2009 mbp as well as moving the sleep magnent, but that is a minor issue. Please respond ASAP! The auction ends soon and I need to know what to bid.
回答がありました! View the answer 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメント:
Please give the model numbers for both machine.
による
A1286, 15" late 2008 MBP
Display is from a mid 2009 MBP pro of the same size. (later model but same A1286 identifier)
による
コメントを追加
Pro Tech ツールキットを含むご注文、もしくは総額 $100ドル以上のご注文については送料無料です。
当社のショップを閲覧する
3回答
選択されたソリューション
As long as they are the same model numbers, you should have no problems.
この回答は役に立ちましたか?
スコア 3
コメント:
I am asking as many of the model have the same number (I think the new 2011 model is still A1286). I am asking because the new display (2009) has "605 better color gamut" (whatever that is) according to apple. But did they change ldvs cables between then?
による
コメントを追加
For future internet goers, I believe the Mid 2009 display is compatible, but the display assemblies have magnets on different sides of the screen (however there is a slot on the 2009 one for the 2008 magnet position).
この回答は役に立ちましたか?
スコア 1
コメントを追加
Do not buy any of this, you will regret it when the bottom cover of the display assembly splits - all the 15" do that. They're glued together, it's not one piece, and the heat exhausts onto the exact spot which is glued together. Most on eBay are glued back together with shoddy workmanshop and will fall apart one day outside your eBay buyer protection.
この回答は役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Thomas さん、ありがとうございました!
統計データを表示:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 441
