メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Need tips on disassembly of Tower air fryer
The fryer doesn't power up. I've managed to get to the drawer switch and found it works. Trying to disassemble the rest of the fryer is impossible. The manufacturer gives absolutely no help of course.
Update (01/27/25)
I'm afraid this is all I get when clicking my user name
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
5 件のコメント
What model air fryer do you have? I see that Tower makes different models.
さんによる
Not very clever of me. The model is T17024.
さんによる
Sorry, being new I don't understand what Add You Answer means. I was also trying to put in a photo but it came up with more questions.
さんによる
I'm afraid this is all I get when clicking my user name [image|3538391]
さんによる
Hi @rodisi,
Try here and click on the Create a guide link
さんによる
コメントを追加
2件の回答
ベストアンサー
@rodisi
Here's a teardown video that may or may not help.
I realize that it is for a different model i.e. T17079, but hopefully it still may give you some ideas how to open your model
FYI Here's how to add images to a question or answer in ifixit (it's the same procedure). You can't add images to comments. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Thank you jayeff I shall have a look.
さんによる
コメントを追加
I finally managed to disassemble most of the fryer unfortunately it wasn't the mains fuse or the thermal fuse and seeing all the electronics inside I decided to give up. However, just in case anyone else comes up with a problem on this fryer, I thought I'd post a few pictures on how I did it. It may save someone some time and aggravation.
Top view.
The display panel is first to be removed. This view gives an idea of the clips underneath.
The display comes off with the display board attached.
There are four screw attaching the board to the display. These need separation so the the board can fit through the silver surround.
This is showing the clips under the silver surround. It is a pain in the whatsit to take off. I only broke one of the clips.
Having removed the surround I need to remove the board. Just two cables.
With the board removed the eight screws can be removed. Note the position of the screws as there are four small and four bigger.
This is where I got to and had to stop as my troubleshooting experience with electronics is lacking.
From what I had read about air fryers, the usual problem is the drawer switch and this is where I started. This is the bottom view of the fryer and that sole screw is the first thing that has to be removed. I don't know if somebody else had attempted to unscrew it or whether the manufacturer purposely uses a screw for which there is no tool. With great pain I managed it.
Another six screws to remove.
Revealing the power cable connection
Once this is removed, there is access to the drawer swtch
Good luck.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
Hi @rodisi
Create a guide showing what you've done and then post it on ifixit.
That way it will be easier for people to find rather than trawling through all the answers trying to find it.
Here's how to do this How to Create a Guide
さんによる
I'm sorry jayeff, I have just spent two hours trying to learn how to create the guide and to resize the photos to what is acceptable and the program still won't accept them. I may come back to it some day when I have the time and have calmed down. When I started creating the guide, every photo I inserted, the program wanted to crop it. So I'll come back another day.
さんによる
@rodisi
Thank you for at least trying.
Cheers
さんによる
No! I can't let the damned thing beat me. I don't understand why whatever resize I do of the original photo, the guide wants to crop it. As much as I appreciate the iFixit site I find it the most difficult that I have ever come across and I've been working with computers most of my life.
さんによる
@rodisi
I have the same problem.
I take pictures and then even if taken at what I think is a suitable resolution (or I resize them to 800 x 600) and then try to post it in a guide it still wants to crop.
I don't know what the answer is yet.
If I find out I'll let you know
Cheers
さんによる
コメントを追加
回答を追加する
rodisi さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 18
過去 30 日: 60
今までの合計 663
