メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
The Chevrolet Equinox is a compact crossover SUV from Chevrolet based on General Motors's Theta unibody platform, and introduced in 2004 for the 2005 model year.
How to adjust the headlamps on a 2006 2009 Chevy equinox
Can you adjust the headlights on 2006/2009 Chevy equinox?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
.There is a vertical adjustment screw. However, it is not labeled at all and does not tell you which direction to turn the screw to move the headlamp upward or downward. You don't need to remove the headlamp or need any special tools to make this adjustment. All you need is a regular #2 phillips screwdriver with a reach/length of about 4 inches. If you look just to the outside of the inner screw that holds the headlamp in place, you will see an opening where you can insert the screwdriver.
Hold the screwdriver in firmly and turn the screwdriver clockwise to move the headlamp downward or counterclockwise to move the headlamp upward.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jrdunn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 31
今までの合計 323
