My dashboard indicators aren’t showing
My dashboard indicators aren’t showing, the fuel gauge, temperature gauge, indicator lights
Seu carro liga, mas os indicadores do painel não aparecem e não acendem?
Correto?
No meu Peugeot 207 acontecia a mesma coisa... O carro ligava normal, mas o painel não acendia nada ou as vezes acendia e apagava ... Fui em vários lugares pra resolver e nada dava certo... Até que encontrei o problema...
O problema era o aterramento do painel... Ele fica em baixo do porta moedas... Tem que tirar a capa do câmbio de marcha... Onde vc consegue ver o cabo ( amarelo e verde) com o terminal solto ou o cabo solto... Esse cabo é fixado na carcaça
Google translate:
Does your car start, but the dashboard indicators don't appear or light up?
Correct?
The same thing happened in my Peugeot 207... The car started normally, but the panel didn't light up at all or sometimes it lit up and went out... I went to several places to solve it and nothing worked... Until I found the problem...
The problem was the grounding of the panel... It is under the coin purse... You have to remove the gear shift cover... Where can you see the cable (yellow and green) with the terminal loose or the cable loose... This cable is fixed to the housing
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 21
今までの合計 316
1件のコメント
Hi @reginaldsolomon
What is the year of the vehicle?
jayeff さんによる
