メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2191回答 すべてを表示
Battery iPhone 4s doesn't charge at all
Hi recently I open my iPhone 4S and now my battery doesn't charge instead of showing the lightning bolt icon indicating it was charging, it showed a plug icon. However, as indicated, the battery was continuing to run down so I tried all 3 cords, different outlets, etc. with the same result--the phone only showed a "plug" icon inside of the battery icon and the battery continued to lose charge. I tried turning the phone completely on and off but that only produced the same result. The battery inevitably lost all charge and my phone is now dead. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I have the same thing with my iPhone 3GS i placet a new batery on it but it doesn't work.
さんによる
コメントを追加
3件の回答
最も参考になった回答
on the iPhone 4 check that the 2 tabs on the battery connector line up perfectly with the grooves on the phone. I missed this and my battery did not charge. When corrected all was good.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
My Iphone was not charging before I replaced the battery. No change after battery replacement. Now what?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
there isn't much to mess up on a 4s. The battery plugs into the connector and get screwed down with 2 screws.
Take it apart again and make sure you have everything lined up. If it is, its possible that you got a bad battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Sergio Ruben Sanchez Balam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,438
