How to fix hard steering wheel Chevrolet equinox 2017?
My steering wheel is hard would help me about how to fix it it’s an automatic steering wheel ?
Hi @victorkadima ,
What size engine is in your vehicle?
If it is a 3.6L V6 it has hydraulic power steering so it could be a problem with either the steering pump or a lack of hydraulic fluid due to a leak. Check the level of the hydraulic fluid in the power steering fluid reservoir. The reservoir is located toward the rear of the engine compartment on the passenger side of the vehicle. See image below for location
If it is a 2.4L 4 cylinder engine it has electric steering, so it may be a problem with electric power steering motor.
(click on image)
このアンサーは役に立ちましたか?
It’s 2.4L 4 cylinder engine, yes it’s an electric yeah it says power steering problem
Check if fuse #55 in the engine bay fuse compartment is OK and not blown.
If the fuse is blown then there's always a reason for this to happen. You could try replacing the fuse with a fuse having the same rating and check whether it holds or not and if it does hold then if the steering is back to normal.
If it blows again or if the fuse was OK and not blown, then unfortunately I cannot find a wiring diagram for the vehicle that would show how the motor is operated.
Thank you so much I’ll try to do it
過去 24時間: 2
過去 7 日: 9
過去 30 日: 31
今までの合計 563
1件のコメント
7 days now my steering is head,
I need help to fix it
Emeka company plc さんによる
