メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
Backup wont recognize new hardrive.
MacBook Pro 13" retina early 2015
I installed the latest OS that this MacBook would take. I made a back up.
I installed the new OWC SSD. I attempted to restore from backup after having erased the new hard drive so that it was recognized as MacOS extended Journal. Selected backup and then selected a new hard drive. New hard drive was not recognized and is continually telling me to erase it and try again. No error message beyond that.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Some will say install the OS to the new driver Externally... I had no problems to do it with my new drive internally. I would try giving the 1st method a try but you will need an external adapter to fit the SSD into....
さんによる
コメントを追加
1 件の回答
The version of macOS installed on your system also affects the systems firmware. So if you had Sierra or older (HFS+) on the system the OS won’t have the needed firmware update to allow the newer High Sierra and newer drive (APFS) to boot as it won’t understand the newer file system foundations or even access the drive.
Ideally you’ll need to create an external bootable OS installer USB thumb drive with a newer version of macOS. The last Apple supported version for this system is macOS Monterey (macOS 12).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Maxwell Gordinier さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 139
