メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2020年11月発売。MacBook Pro 13インチモデルは、8コアのCPUと8コアのGPUを搭載したAppleのArmベースのM1 SoC。(モデルA2338 / EMC 3578、Thunderbolt 3ポート2基搭載)
lid sensor location MacBook Pro M1 base model (2020)
Where is the lid angle sensor located on the MacBook Pro M1 (2020)? After cleaning the speaker, the lid angle sensor stopped working. When I close the lid, the screen stays on and the MacBook does not go to sleep. Before cleaning the speaker, it was working perfectly. Can you help me locate the lid angle sensor?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント:
Which model? 13” or 15” they are different
さんによる
@danj 13" sir
さんによる
コメントを追加
1 件の回答
The Hall sensor is mounted on the backside of the logic board which I’ve marked here. This is not an angle sensor design which is used on the 15” models.
画像
Using a rare earth magnet passing it over the top surface of the palm rest you should be able to fire it off. If not could you have damaged it?
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
If that’s indeed its proper place, it should be out of reach. Could it be possible that it got dirty while cleaning the speaker?
さんによる
@maulanarafi - Dirt won’t effect it, but some liquids could effect things here, basically creating a short. How did you clean the speakers? Did you use a water based cleaner or one with ammonia.
さんによる
@danj No, I didn’t use water. But could it be fragile? I only used a used toothbrush to clean the dust from the speaker holes.
さんによる
@maulanarafi - Well… I wouldn’t call it fragile, but like most SMD devices the solder joints hold the part to the PCB so it’s possible to knock it off. But there are other components also involved in the sensor for it to work. So you will need to compare the logic board with the one I posted to see around the area if there is a component missing. You’ll also need to look on the other side as well as not everything is on one side.
さんによる
コメントを追加
回答を追加する
Maulana Rafi さん、ありがとうございました!
統計データ:
過去 24時間: 11
過去 7 日: 32
過去 30 日: 120
今までの合計 1,436
