メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
初代Xboxは、Microsoftで初めて広く普及したビデオゲームコンソールです。上面と前面に「XBOX」の文字が入った黒いケースで、簡単に識別できます。修理は一般的な工具で簡単にできます。
Solder pad ripped off
Hi!
While de-soldering an SMD capacitor (the round, silver one, 47 μF 16V) from my Xbox Original, I ripped off a solder pad.
What can I do now? Do I need special tools to solder on a new one? Or can I just leave it out, what would happen if I do?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
You might be able to get away with leaving it off, but these larger caps I tend to think are probably ones you'll want to replace. I can't tell for certain from the pictures, but it's very possible that side of the capacitor was on ground (which honestly would make sense to me, that will be the side that's harder to desolder because it can absorb more heat since the ground plane is quite large).
If you still have the capacitor, check which side the torn off pad is on. Is it on the positive side or negative side? It will generally be labelled as such. See the other cap in the picture, there's a vertical white stripe on it with minus signs to designate it's the negative side. Negative side means it's the likely the ground side, so would be much easier to repair.
Consequences of leaving it off could vary. My inkling based on the width of that trace is that it's a major power rail and chances are it's got lots of caps, so one missing may not have huge consequences. But could mean components on that rail may wear out faster, or potentially something may not work at all depending on the purpose.
I would confirm with a multimeter in continuity mode that that side was in fact ground, by probing the little vias at the end of the little traces that pulled up and seeing if they are continuous with a known ground (areas around screw holes are usually a good bet). If ground, just make sure that leg of the capacitor gets soldered to a ground point and you'll be golden. You can repair the little traces if you want, but it may not be necessary.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Just adding that you almost definitely ripped off the negative pad, looking at this high-res image of a motherboard, you can see similar capacitors on top of that same footprint. Schematics for most revisions of the Xbox motherboard can be found online, and you could use that to confirm that this capacitor's negative pin is routed to ground. If so, then it's a pretty easy repair and you could resolder the negative end to an adjacent component electrically connected to ground.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@flannelist @chrisgreen
Thanks for your answers! I made a better picture: https://ibb.co/s2HjHt4 and I found the schematics. I've attached them. It seems like the capacitor is used for the LAN port in some way. But would it be important to solder it on if I don't use that port?
Someone also sent me a picture from where to where I should solder on a jumper wire, is that correct?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arthur さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 7
過去 30 日: 33
今までの合計 396
