メインコンテンツにスキップ
海洋や大きな湖で波を利用した水上バイクです。
2回答 すべてを表示
Can I use normal Solar Rez to repair my epoxy surfboard?
I have an epoxy/Boardworks Hynson twinzer with a few small nicks. I want to patch it up before I sell it but I don't want to ruin the paint on my board or mess anything up. Can I just use my standard solar rez to repair any dings? Will it adhere?
Here is a link to my board
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
4件の回答
選択されたソリューション
Standard solar rez is for fiberglass board. Since your board is expoxy you should use an epoxy ding repair kit. They aren't as common as your typical ding repair kit, but they sell them at most surf shops. The fiberglass based solar rez won't provide a high quality fix.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Do you have an online link?
さんによる
コメントを追加
最も参考になった回答
Do you have pictures of the dings? The color is most likely under the clear epoxy, so surface repairs shouldn't damage the color directly. Repaired spots will probably be "foggy." You can fix this by sanding the spots with fine-grit sandpaper and then wiping with board wax.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
do you surf?
さんによる
コメントを追加
if the ding in your epoxy board goes all the way to the foam you cant use anything but epoxy cause if you put solar resin or sun cure or regular fiberglass resin it will melt the the foam and you'll have a bigger hole than you started with but if its just a crack rough it up with some hundred grid than glass it with sanding resin than sand it again until its flat than reapply another light coat of sanding resin
and than sand it with 200/150 grid until its smooth
than if you want match the color you want spray a light acrylic color than spray some clear coat and sand it with wet sand paper like 1500 grid if you do it right you cant feel or even see it
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
thanks for the new information.
さんによる
コメントを追加
epoxy putty from Lowe's are Home depot. Easy to use. David
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brady Cabe さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 59
今までの合計 10,101
