Power Cord won't plug into the console
There is a peg in the middle of the socket that dosen't match up with the desigh of the plug from the power supply. Do I have the wrong power unit?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
LeeB, there are three different power supplies for the xbox360. If you have a peg in the middle of your plug, you will need a 203watt power supply. Take a look at the image and more information about this on here. So, you have the wrong power supply for your unit. Hope this helps, good luck.
このアンサーは役に立ちましたか?
i have a Xbox 360 arcade and do all Xbox´s run on the same power cord
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 16
過去 30 日: 75
今までの合計 19,390
